8N won't run
   / 8N won't run #1
farmerdean
NW missouri
1947 ford 8n
1947 8N been doing good till last week. Died while idling. Ran the bat down trying to restart. Charged the bat & tried again. Started a few times but died in less than a minute. Tapped on the carb with a wrench, fired up & ran just fine halfway back to the house. Spent the next few hours getting it 1/8 mi. to get it off the road & into the drive. next day pulled the carb took it apart, plenty of carb cleaner, put it back together. same thing. Took the carb back apart, removed all the orifices and needles, cleaned everthing with carb cleaner & compressed air, put it back togrther. Same thing. Carb & dist. were rebuilt about a year ago. Also replaced plugs, volt reg. & all wiring at the same time. Checked the spark on one plug, looked blue. Good gas flow through the carb for at least 2 min. Good airflow through gas cap. It will start repeatedly, just won't run for more than a couple minutes at most. usually much less. Cleaned the bowl too, not much in it. Batt has a full charg on it. I'm stumped.
   / 8N won't run #2
at point of sdeath.. check spark.
hotwire the coil as a 2nd check.
if spark stays good and it won't run.
it HAS to be fuel.
   / 8N won't run
It was the condensor. Thanks for the help.
   / 8N won't run #4
glad ya found it!
2018 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A52705)
2018 PRINOTH...
Kivel 48'' pallet fork attachment, 3500# capacity (A53421)
Kivel 48'' pallet...
2014 KENWORTH T800 (A53843)
2014 KENWORTH T800...
2025 IR UNUSED Hydraulic Breaker (A53117)
2025 IR UNUSED...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A51694)
2014 Glasstream...
