Mowing 8n with a 72" finish mower
   / 8n with a 72" finish mower #1
ezzy
tennessee
1952 Ford 8n
8n with a 72\" finish mower
I just bought a ford 8n with a 6' finish mower, is there enough horse power through the pto to run a 6' mower
   / 8n with a 72" finish mower #2
Re: 8n with a 72\" finish mower
yup.
Welcome to tbn. My TC18 (14 PTO HP) runs a 5 footer just fine. The 8n has a bit more HP...
PS no need to post in two different locations
   / 8n with a 72" finish mower #3
I think the 8N had about 25 hp??? That would probably put the PTO hp about 18 or 19. Don't know how much torque there is in the engine but I think a 6' finish mower would probably work pretty well but might bog down with wet grass.
   / 8n with a 72" finish mower #4
According to the I&T service manual, which has its info from the nebraska tests. The 8n has 27.x belt hp.. and about 23.x pto hp. 9n and 2n tractors have a fraction less hp, due to a lower compression ratio ( 6:1 9/2n 6.5:1 8n ).
Lots of people run 6' finish mowers on there N's. Some like 5's if their lift is weak. If you are getting too much of a bit on the 6' swath.. just cut 5' or 5.5'
Soundguy
   / 8n with a 72" finish mower #5
I think you'll be fine. Two conditions could make it marginal - grass gettting too long and not able to fly out of the mower deck fast enough and second, going to fast of a ground speed. In either case, all you have to do is slow the ground speed a bit while keeping the RPMs up.
   / 8n with a 72" finish mower #6
I would be best if you put an overrunning clutch in the pto shaft to driveline connection as well. This can help if you need to stop in a hurry for some reason. There has been lots on this issue here. Try a search for overrunning clutch.
Dane
1.5 Rolls of Red Brand Barb Wire (A50515)
1.5 Rolls of Red...
2011 JOHN DEERE 310SJ BACKHOE (A51242)
2011 JOHN DEERE...
1998 JOHN DEERE 310E BACKHOE (A51242)
1998 JOHN DEERE...
2018 JOHN DEERE 700K LGP CRAWLER DOZER (A51242)
2018 JOHN DEERE...
2011 PETERBILT 337 (A52472)
2011 PETERBILT 337...
UNUSED FUTURE MINI EXCAVATOR HYD 12" AUGER (A51244)
UNUSED FUTURE MINI...
