8N will not start
   / 8N will not start #1
Chuck1949
Pa
BX-24, Ford 8N 1949
I have this 8 N for a few years, replaced a lot of parts, I have new electronic ignition, coils, rotor and cap. It was running fine til one day the rotor contact burnt off. Since then I can't get it to run. Any ideas?
Chuck
   / 8N will not start #2
I sold my 8N 15 or so years ago, but one thing I loved was the simple maintenance. Problems where, as defined by my late FIL, usually either spark or fuel. So, are you getting a spark at the plugs? If yes, then check for a fuel problem. If no, then figure out why. Since you say it has an electronic ignition and the rotor contact burnt off, I'd start there. Perhaps a short?
Good luck,
   / 8N will not start #3
Chuck
Chuck, I agree with Barry. The 8N has a very simple ignition and fuel delivery system that are normally easy to troubleshoot. Your addition of an electronic ignition may have added some complexity to the equation.
You said the rotor was burned. Normally, the rotor does nothing more than take the high voltage pulse from the coil and route it to the proper spark plug. The circuit is open because of the spark plug gap. There is no way any short circuit should exist that would not be obvious. Perhaps your spark is so hot that it welded the rotor contact to the distributor cap contact. Maybe the cap is the problem now. Are you sure the cap is seated properly?
If you are not getting a spark to the plugs, then the next thing to check is the coil. You can check this easily by checking for power to the coil when the key is turned on. Next, on the output side of the coil (the wire that goes to the distributor), remove the wire. Also, pull the coil high voltage wire going to the top of the distributor and put it about about 1/8 inch from a good ground. Now, ground the small output wire from the coil momentarily. When you remove the ground, you should see a nice spark from the high voltage coil wire to ground. If you don't, the coil may be bad. Other wise, if you get a spark, then your problem is internal to the distibutor and the electronic ignition.
When you installed the new ignition, did you put a ballast resister in series with the input to the coil? Was the coil the original coil or supplied with the converstion kit. Is it a 12V coil? Many/most 12V coils have an internal ballast resistor, but if not, yours may need one. What the ballast does is to keep the points from being a dead short to ground when they close. The ballast resistor is an addition to the resistance of the ignition coil's windings and will keep points from burning out. I'm just not sure whether your electronic ignition needs something similar. That's why I said earlier that your troubleshooting may be more complex.
If you are good with a voltmeter, you can figure out where the problem is without all the things I mentioned earlier, but you can normally troubleshoot a simple 8N electrical system without any use of a voltmeter or other test equipment if you know how.
Good luck.
   / 8N will not start
The electronic ignition ran great in the past. Cap and rotor are new. I will test the coil tomorrow, my system has a after market 12 volt coil, should I go back to a Ford 6 volt coil?. Thanks for your help.
Chuck
   / 8N will not start #5
Is this the front mount or the side mount distribuitor, and is it converted to 12v ( sounds like it is ).
Is this the pertronic 12vneg grnd kit?
soundguy
2004 FREIGHTLINER FL70 FLATBED W/TANK & DITCH WITCH MIXER (A53843)
2004 FREIGHTLINER...
2015 Ford F-150 (A53422)
2015 Ford F-150...
2012 FREIGHTLINER CORONADO (INOPERABLE) (A53843)
2012 FREIGHTLINER...
2010 John Deere 200 Crumbler Seedbed Finisher (A53117)
2010 John Deere...
2011 CIRCLE M 32 FOOT GOOSENECK (A53843)
2011 CIRCLE M 32...
2011 Mitsubishi Outlander AWD SUV (A51694)
2011 Mitsubishi...
