It's also very easy to make the 8n have live hyds with the addition of an aux engine mounted hyd pump.. like a power steering pump, or thru a front stinger pump. Just need a pickup line, and pressure can be routed to the test port on the pump bas plate. OEM relief valve and intake exhaust valve will work fine with this setup... though you have to switch to the 134d type oil instead of the 90wt lube, and will need to add a filter for the aux pump due to the open sump design.
There are a couple people making these live hyd kits for the 9n, 2n, and 8n... Gives you 2x speed onthe lift and 1x speed on t he lift with clutch pressed in.. also great for adding a true live remote..
Soundguy
