I was using my Ford 8N and shut it off. When I went to re-start it, it wouldnt turn over and started clicking. It appears to be coming from the solenoid and it appears to be sparking a little bit. Any idea on how to fix this?
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
if you can see a spark.. that menas a loose connection. loose connections are HORRIBLE about condicting electricity.
remove and clean all bat cables and terminals, conencts to solenoid and starter, adn the ground strap to the fram. add a lil grease to the conenctions.
