8n Rear axle bearings
   / 8n Rear axle bearings #1
calh22554
mn
ford 8n
Ok so I replaced the inner and outer seals on my 1950 8n. I found out my hubs were worn so I replaced those too. I've done the axle pre load with the shims according to the FO manual so the hubs turn in opposite directions. What I'm not clear on is how tight or how hard should it be to turn the rear hubs when I put them back together? I have to use both Hands and put a little more effort into turning the hubs than I thought would be normal. Do I have the bearings too tight? Maybe I need to add another shim on the litter race?
New Holland TS6.130 4WD Utility Tractor with Rotary Mower (A53421)
New Holland...
1837 (A51248)
1837 (A51248)
2017 JOHN DEERE Z950M LOT NUMBER 83 (A53084)
2017 JOHN DEERE...
2019 Chevrolet Tahoe SUV (A52377)
2019 Chevrolet...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
