8n overheating
   / 8n overheating #1
wiskers8n
tn
8n
I have a 47 model 8n that has been overheating since I bought it. i'll start bushhogging and about 20 min into it starts blowing steam out of the radiatior. I put a temp gauge on it and the steam starts when it hits 200. I have replace the radiator, put a head gasket on and took out the termostat. Dont know if it could be the waterpump or i need to put a electric fan on it. Any help would be apperciated
   / 8n overheating
Wouldn't there be water in the oil if the head was cracked?
   / 8n overheating #5
I presume you checked the fan belt tension already. You can check for proper water pump function by taking the radiator cap off and looking for good flow through the radiator. Some cooling systems don't work as well without a thermostat. Don't know if 8N is one of them but if flow is not very obvious then try putting new thermostat back in, easier than water pump.
   / 8n overheating #6
there are no oil passages in a flathead on an 8n.
an electric fan on an 8n is like an escape dingy on the space shuttle.
check the water pump.. impellor might have rotted off.
removing the thermostat is a horrible idea...
soundguy
   / 8n overheating #7
I had the same issue with mine, turned out after pulling radiator and the head I had the wrong radiator cap. But at least I found out the head was good, the radiator flowed Ok. The new cap cured the problem.
   / 8n overheating #8
Is the belt tight on the water pump?
What did the coolant look like when you changed the water pump?
Is the fan on the correct way?
   / 8n overheating #9
So, somebody please tell, what IS the right radiator cap for these old Fords? Is it the same cap for all 8,2, 9, 600, 800, 4000? Teach us how to know what to use, please, thanks.
   / 8n overheating #10
4 psi, if a pressure cap.
early N have a non standard, non pressure cap.
Zerex 50/50 Anti-freeze (A53117)
Zerex 50/50...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2010 Chevrolet Tahoe SUV (A50324)
2010 Chevrolet...
2019 Chevrolet AWD Equinox SUV (A51694)
2019 Chevrolet AWD...
2019 TRITON TRAILER ALLMAND MAXI LITE 45 GENERATOR (A53843)
2019 TRITON...
2025 SDLANCH SDLGC80 UNUSED Electric Golf Cart (A53117)
2025 SDLANCH...
