8N over run clutch removal?
   / 8N over run clutch removal? #1
snooks
Bronze Member
Virginia, IL
YM2500
I need to remove the over run clutch from the PTO shaft of my 8N. After removing the grease fittings, I expected to see a roll pin. I found no pin and I been unsuccessful in getting the clutch to slip one way or the other. Any suggestions would be helpful. /forums/images/graemlins/confused.gif
   / 8N over run clutch removal? #2
Jeff, I don't know, but doesn't it have a spring loaded pin on the tractor side just like the one that releases the implement drive shaft. I think you can see what I'm talking about on the lower part of page 8 at this site. Look at the lower left part of that picture.
Bird, I went to the farm store tonight to look at the same over run clutch that I have on my tractor. I discovered that the clutch should slip when I rotate it clockwise when looking at it. Apparently mine has froze up a little, which might explain why it would sometimes push me when the mower is on and I try to stop. So, I got my son to set on the tractor with it in gear and his foot on the break, while I attached a big pipe wrench to the over run clutch. Now armed with the knowledge of which way it should turn, I put all my weight into it. Low and behold it moved (after turning the engine over a little). It is free and I was able to line up the hole with the roll pin. All down hill from here. Thanks for the reply. /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif
   / 8N over run clutch removal? #4
Glad you got it done. /forums/images/graemlins/cool.gif
2018 DRAGON ESP 130BBL VACUUM TRAILER (A53843)
2018 DRAGON ESP...
Echo Weedeater, Stihl Pole Saw & Predator Gas Auger (A50123)
Echo Weedeater...
2012 Diamond Cargo Enclosed 24FT T/A Cargo Trailer (A51694)
2012 Diamond Cargo...
2013 Chevrolet Silverado 1500 4x4 Ext. Cab Pickup Truck (A52377)
2013 Chevrolet...
2025 Swict 72in Bucket Skid Steer Attachment (A51691)
2025 Swict 72in...
2013 Freightliner M2 106 Water Truck (A53117)
2013 Freightliner...
