8n or 9n
   / 8n or 9n #1
Pipes
Trumann, AR
1952 Super C
Saw and ad for a 1939 9n serial number 9n1498. The picture with the ad had small bolt circle on rear tires. I have been told the 9n's all had large bolt circle. Is this true? Thanks, Don
   / 8n or 9n #2
There are 2 easy tells for me concerning 8N's. All have transmissions with 4 speeds forward/one reverse. All have a single nut about 2" across the flats holding the rear wheel hub to the axle shaft. 2N's and 9N's have neither feature. NAA"s have the axle shaft nut, but an overhead valve engine.
N series serial numbers are only found on the engine cylinder block. A replaced engine clouds the picture considerably.
   / 8n or 9n #3
ditto what rick said.
many times it's an engien swaps.. other times it is someone randomly picking a casting number and thinking that is a sn vs a hand stamped one.
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
2003 Club Car DS Electric Cart (A51694)
2003 Club Car DS...
2014 DRAGON 500 BBL FRAC TANK (A53843)
2014 DRAGON 500...
Cruise Car Inc. Electric Golf Cart (A53117)
Cruise Car Inc...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2011 V.E. ENTERPRISES 130 BBL STEEL VACUUM TRAILER (A53843)
2011 V.E...
