8n only runs with full choke
/ 8n only runs with full choke #1
fibrostic
I have an 8n that was running a little rough and needed to have the choke out to run smooth. I thought it was a carb issue, so I bought a replacement and replaced it, still pretty much doing the same thing, that requires it to almost be full choked to run. Is this a gas mix issue? I have tried to alter the fuel mixture screws but not getting anything that seems to work, ideas? Could this be a points issue? I put new wires on as one had a small cut, but cant imagine that is doing anything.
/ 8n only runs with full choke #2
9 times out of 10 when I have seen this in boats and out door power equipment its bad gas or more commonly water in the fuel. I would drain everything, including the carb bowl and start off with fresh fuel after a rinse of the tank.
I would replace that wire no matter what. Electrical tape for the time being.
Chris
/ 8n only runs with full choke #3
I find that most often when an engine will only run with choke, the jets on the carb are plugged. Find where the jets are, and open it up so you can get to them. Then take a thin piee of wire and poke it through the jet to knock out any junk in there. Rinse it with carb cleaner, put back together, and it should be good to go.
/ 8n only runs with full choke #4
I'll go with Deerman 75.:thumbsup:
if you changed the wires check the firing order and the wires.
/ 8n only runs with full choke #5
Like Diamondpilot stated I would start with your fuel. It seems you are starving for gas or clean gas. You may have aready checked your tank and sedlment bowl but on my old tractors sometimes it is tank that has years of accumilated stuff and sometimes a very fine rust that can slow the flow.
So i guess i should have given more info. I have drained the tank, replaced the line prior to bolting on the new carb.
/ 8n only runs with full choke #7
Sounds like a intake leak might be the culprit here.
/ 8n only runs with full choke #8
You need to start eliminating causes. If you replaced and clean the tank and have fresh fuel and satisfied with that, move on to the carburator, depending on the where the replacement came from how confidant are you that it is clean? Then move on to the adjustments and then check the linkage to make sure it is not binding, then check the governor linkage, it maybe sticking/worn out, make sure all the adjustments on the carb are back to factory if they are out it will never run right. If that is good check for intake leaks. I am pretty sure it is combination carburetor adjustment/governor.
My two cents
/ 8n only runs with full choke #9
With the engine running rough, spray carb cleaner around the gasket between intake and cyclinder head. If the gasket is leaking your engine will run better when the cleaner is being sucked in. I have had to replace many of intake - exhaust gaskets on N series Fords over the years.
/ 8n only runs with full choke #10
New carb? How was float level set. How were the fuel jets set? :thumbsup:
/ 8n only runs with full choke #11
Is this a tractor you have had for awhile and used to run good or one you just got? Altitude?
/ 8n only runs with full choke #12
did that carb have new screen filter elbow where the fuel line connects and is it clear?
getting a good flow to the carb when you turn the fuel on?
/ 8n only runs with full choke #13
There are at least two possibilities: a weak spark requiring a richer mixture(the usuual suspects are maladjusted, burned, dirty, corroded or oily points, high resisitance in the primary ignition circuit), or an air leak around the metering section of the carb (the usual culprits are worn throttle shaft, leaking carb to manifold gasket, cracked or rusted intake manifold, or a leaking manifold to cylinder head gasket).
Which distributor do you have, front mount or side mount?
/ 8n only runs with full choke #14
needs choke to run:
plugged fuel delivery ( rank to carb and all inbetween must be checked )
weak spark
vacume leak.
choke enriches a mix.
rich mixes fire easier ( weak spark )
vacume leak leans a mix.. choke re-enriches it.
post back what ya find.
OK so today I installed all new fuel sediment trap with both screens, and a new elbow with screen going into carb. Fuel flow from line going into carb is solid stream, the flow coming out the drain on the carb is more than a trickle but not a solid stream.
Currently if you let it sit for a couple minutes you can keep it going for about a minute, then it starts and dies after a couple seconds. Thus my thought is something is clogging the fuel getting into the carb. Could this be a needle valve issue? If so, what can i do? are there adjustments on it?
*Update*
I think i mean float valve and not needle valve.
*Update 2*
So i pulled the carb off again, tore it apart and really checked the action on the float and the float valve. Noticed that it seemed to be sticking a bit...maybe..., so i took it all apart flushed everything with cleaner and polished the little float needle and the seat. put it back together and it ran much better, though still running weak. I turned the gas valve all the way open and it runs like a champ (note the little circle that acts as the handle on the sediment bulb came off when i opened it all the way up, and of course i lost the screw) Now the question is, problem fixed?
/ 8n only runs with full choke #16
likely the fuel flow issue is fixed.
the old fuel taps, had 2 settings.. open and open with reserve. it was 2 different heights of pipe in the fuel inlet.. nowadays there is only 1, so just open the valve all the way. plus some valves have the lil orifices not drilled perfectly, so anything less than full open can impede flow.
if it is a bras needle and not a viton needle for the float, then yeap.. a lil polish with rubbig compound or toothpaste ont he needle, and a toothpick into the seat helps. also making sure adjusted to 1/4" ( i use a drill bit stem as a gauge ) and making sur ethe flaot does not hang up, nor has a pinhole in it.
if it seems weak, enrich the main needle 1/8 a turn at a time and gun the hand throttle .
lean fuel setting will make a slow rise or stumble and rise of the rpm.
correct setting provides a good acceleration of rpm, and no heavy smoke out the exhaust, though a puff is ok.
rich meaks sooty black smoke out the ehaust upon throttle up, and may gurgle an semll rich and stumble a bit int he top end as if you were choking it ..
soundguy
So was running the 8n last night, drove all over the property without issue in 1st to 4th gear. Was extremly happy that it sounded bettter than any other time i had owned it. Went down to the barn and hooked it up to a spreader (ground driven). About 2 minutes into the field it started to bog down and started to learch, die and rev, die and rev, etc. Had to limp back to the barn and switch tractors. This is getting old fast.
/ 8n only runs with full choke #18
Did you check the vent on the fuel cap ?
E/S
2004 International 4300 ASM Altec AM855 55ft. Bucket Truck (A64194)
2004 International...
2011 Nissan Murano SUV (A61574)
2011 Nissan Murano...
2016 FORD TRANSIT CONNECT PASSENGER VAN (A59912)
2016 FORD TRANSIT...
2025 Wolverine MCB-11-48W 48in Hydraulic 4-Way Clamshell Bucket Skid Steer Attachment (A61572)
2025 Wolverine...
2019 JCB LSB72 Compact Track Loader Skid Steer (A61572)
2019 JCB LSB72...
2019 KUBOTA KX057-4 EXCAVATOR (A62129)
2019 KUBOTA...
