8n Lift
   / 8n Lift #1
mmasters
Ford 8N, lift will lift and hold with engine off a while (seems strong). (the following is with an implement)= When position control is lifted over 1/4 up from bottom, lift raises to top (regardless if you push position control back down) and when it reached the top, it "releases" and goes back down to a reasonable height depending on where the position control is at that time. It acts similarly it draft or position control with a little more position control in the lower quadrant only when in position control mode (and not draft). Any assistance is appreciated
2015 International DuraStar 4300 Ambulance (A51692)
2015 International...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A53473)
UNVERFERTH 330 -...
2017 Makita HM1307CB 35lb Demolition Hammer (A52377)
2017 Makita...
2021 Harley-Davidson FLHP Motorcycle (A51694)
2021...
Kivel 48'' pallet fork attachment, 3500# capacity (A53421)
Kivel 48'' pallet...
