8N, Jubilee sherman
   / 8N, Jubilee sherman #1
shawty
ford 8n
I own a good solid Jubilee tractor. I ran across a 1952 8N a few days ago with a 5' bushhog and boxblade for 1200 bucks. When i went to look at the tractor i was expecting a pile of junk, but to my surprise it was a solid tractor with new back tires and it had a sherman combination transmission in it. Everything works great on the tractor. I was wondering if the sherman would fit in my Jubilee and if so how big of a job would it be to swap out.
   / 8N, Jubilee sherman #2
Yes, it will fit. The issue is locating and drilling the hole for the Sherman shift lever shaft. Otherwise its pretty much just swapping parts. The Step Up / Step Down transmission was used into the mid-1960's as a dealer installed add-on.
   / 8N, Jubilee sherman #3
offhand i don't know if the n and naa sherman are the same.. but guess they are as the # 2n7017a is the pn for the input shaft on both the n and naa.. so you'd need to swap the input shaft over if you did the swap.
soundguy
   / 8N, Jubilee sherman #4
Memory sez the Sherman replaces the input shaft. Course the last (and only) one I did was about 45 years ago.
   / 8N, Jubilee sherman #5
Geeezzee, don't let a little time fog up the ole memory..How come can remember all this crap I've repaired and where the spare parts are,,,But can't find my .357???
   / 8N, Jubilee sherman #6
of course it repalces the input shaft.. :) no room otherwise.. :)
soundguy
Thanks! I will hopefully start the swap as soon as this tropical depression stops dropping all this rain. I cant complain because it is needed.
2017 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2017 Ford F-350...
4- 12 TOM JACK STANDS (A53843)
4- 12 TOM JACK...
CATERPILLAR CB24B SMOOTH DBL DRUM ROLhttps (A52705)
CATERPILLAR CB24B...
5TH WHEEL HITCH (A53843)
5TH WHEEL HITCH...
2021 JOHN DEERE 524P WHEEL LOADER (A52705)
2021 JOHN DEERE...
2018 LAMAR TRAILER 40' T/A GOOSENECK TRAILER (A53843)
2018 LAMAR TRAILER...
