8N charging problem
   / 8N charging problem #1
simonmeridew
Northeastern Vermont
Kubota L4400
My 51 8N isn't charging. Wiring is intact and continuity is there. Ammeter shows slight movement to the neg side when the key is turned on, but starting the engine doesn't resolve this like it used to do. The contacts don't appear stuck in the regulator, as far as I can see. Are there brushes in the generator that could be worn? How do I get at whatever could be wrong?
simonmeridew
   / 8N charging problem #2
1. First, polarize it by jumpering BAT to ARM, then restart.
2. If no charge on ammeter, at 1000 rpm, then jump field post to ground, if charge jumps up... V/R bad - Replace.
3. If still no charge, leave that jumpered and now jump BAT and ARM, if charge comes up then cutout and possibly field circuit is bad. Again, replace V/R.
Note: The full field test makes the gen charge at max so do not leave it jumpered for longer than it takes to read the ammeter.
4. If that provides no charge, then you need to motor it with the engine off. If still no charge do a motor test... Remove belt, jumper BAT to ARM, and ground the FLD. Gen should spin if it is good.
   / 8N charging problem #3
Db got you covered on the test yo need to make to decide if it is gen or vreg.
post back what ya find.
tractor's at my son's right now, be a few days till I can test. will do it, then get back. thanks for your testing advice
simonmeridew
   / 8N charging problem #5
do let us know. might be something free/simple/easy
2024 CFMoto Cforce 600 4x4 ATV (A51694)
2024 CFMoto Cforce...
2014 SHOP BUILT  DISCHARGE MANIFOLD (A53843)
2014 SHOP BUILT...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
Valvoline 80/90 Gear Oil (A53117)
Valvoline 80/90...
2008 Chevrolet Trailblazer SUV (A51694)
2008 Chevrolet...
2017 Ford Explorer SUV (A51694)
2017 Ford Explorer...
