Get yourself a stabilzer bar kit from TSC if you want to use that rear scoop in the reverse position, otherwise you will make pretzels out of the lower links. While you are there, as SG already said, pick up an ORC to make the PTO operation a lot safer. If the tractor is 6 volt and still starts good, keep it that way. Point life is better and resale is higher. Whatever you do, dont put a front loader on that tractor. Takes away the advantages of excellent power/weight ratio, manuverability and easy accessabilty to operator platform. An 8n was the first tractor I bought and I would never be without one. I dont believe any tractor designed since, especially from Ford, can hold a candle to one. Learn and adapt to its limitations and it will serve you well. Few machines have as much durability and certainly none has better parts availability.
