I would first have to ask why? What is the main goal here?
Like soundguy said, if the goal at the end of the day is to have a "usable" tractor, move up to the 600/800 series. More power and live pto/hydraulics. Not to mention an higher re-sell value.
The 8ns MUST have the PTO running to raise the 3PH. And everytime you push the clutch to start/stop/change gears, the PTO stops. A real PITA for mowing or bushhogging.
But it your only goal is a project and the challenge of a restoration, the 8n's are probabally about as easy as they come:thumbsup: But just keep in mind that unless you buy one dirt cheap, you are probabally going to have more $$$ invested than it is worth.
If you do decide to go with the 8n, a few things to look for in a good one.
1. Later side distrubutor is better.
2. Sherman pre-transmission. The ones that offered step-up step-down gave the thing a 23MPH road gear. Very nice for going places in a hurry:thumbsup: And an added selling point (if re-sell is the goal)
3. Personal opinion here, but look for one that is the origional 6v system. When the engines got tired and needed rebuilt, they got VERY hard to start. TOO many people took the easy way out and went to 12v. I like the origional 6v systems. And unless a regulator/resistor was used, the starter suffered. Same goes for jump-starting directly to the starter with a 12v battery. It is too easy to knock the bendix off the end and then you have to fish it up out of the bellhousing. (dont ask me how I know:confused2
And if you plan on doing a COMPLETE restore, a couple of things that I would plan on right from the start.
Change the PTO-shaft. The 8n's were 1-1/8" 6-spline. Current standard is 1-3/8". Instead of using adapters, you can buy a whole new PTO shaft for ~$150.
Second thing is I would rebuild the 3PH lift cylinder. The 8n's had metal seals (kinda like piston rings) and they blead off pretty fast. The replacement for it is a new piston and o-ring style. It will hold an implement up for weeks on end provided the bore of the cylinder isnt tore up.
Good luck and keep us posted when you get started. Dont forget pleanty of pics as well:thumbsup:
