8n/48/front mount
   / 8n/48/front mount #1
tlh178
when the governor is old and leaking alittle oil. will you loose oil pressure. i have 15psi at start up and drops too 5psi when its warm.
   / 8n/48/front mount #2
The governor is the least of your problems. Check the oil pressure with a gauge of known accuracy. You have a faulty gauge, worn crankshaft bearings, a worn oil pump, bad pressure relief valve, or some combination of all.
   / 8n/48/front mount
thanks rick. sounds like its time too strip her down and start replacing some parts. i did replace some of the old oil lines. getting some leakage there also. not sure if i'm losing some pressure there. i didn't use any type of thread sealer. figured the flare would be leak free!
   / 8n/48/front mount #4
oil pressure is already likely leaking off thru a worn pump with excessive clearances, a weak relief spring, or the main and rod bearings as rick indicated.. or thru the cam and parent bore in the block that is not easilly renewedwithout custom machined inserts.
i'd do what rick said.
1, stop the leaks, 2, get a new gauge.. do an oil change to a good oil like a 15w40.. if she's still real low.. you have a couple options.
whole hog rebuild.. or a poor mans job.
if she starts fine and has plenty of power, drop the pan and roll in new main and rod bearing shells fo the same size as came out. if you want more work.. rebuild the oil pump.. that may require a trip to the machinist.
if she's a lil weak, pop the head and hand lap the valves, and throw a set of rings in her.. lightly hone the cyls for crosshatching and ream the ridge at the top of the cyl to protect the new rings.
cost is liekly less than 100$ for the poor mans upper and lower, even including the pan and head gasket.
renew or stretch / measure the oil pressure relief valve spring to make sure it is not broke or too weak / short.
that all togher usually buys you a few psi oil pressure and compression.
6 psi minimum at 1000 rpm is the red line go / no go number many people used. i like to see double digits on a working N when it is at pto rpm though. 20w50 oil might get you there in a bad case scenerio.
realize that is a bandaid.. much as the quickie 'before lunch' upper and lower I told you about too...
soundguy
   / 8n/48/front mount #5
I had a problem with my 8N oil pressure. When it was hot outside and I worked the tractor hard the pressure dropped right off. I switched to 20w50 motorcycle oil and I haven't had a problem with it since.
I recently took the engine down to put new rings in it and all the bearing surfaces, crank, and cam look like new so it must like the 20w50 oil just fine.
   / 8n/48/front mount #6
was the block where the cam rides wore? without custom machined inserts, it is essentially non renewable, and a significant source of oil pressure loss.. oil pump wear is too.
UNUSED RAYTREE RMLS18T WOOD SPLITTER (A51248)
UNUSED RAYTREE...
2010 International 4300 2,000 Gallon Water Truck (A52377)
2010 International...
1997 International 9300 Day Cab Tractor (A52384)
1997 International...
HYD PUMP & TANK SET (A51248)
HYD PUMP & TANK...
