8AM Saturday
   / 8AM Saturday #1
Republic of Texas
Bronze Member
North East Texas
John Deere 850 - Yanmar 3110D
4:30am - Wake up. Not sure why. Start thinking of all the projects I want to work on. Think till 5.
5:30am - Shower took, coffee made. 27 degrees. Temp low, but spirits high.
6:00am - Go outside.
6:03am - Go back inside.
6:05am - Check weather. Hang out on TBN.
6:30am - Little boy wakes up. Pigs n a blanket & chocolate milk. Play dinosaurs & tiger, his rules.
7:00am - Brother shows up to check feeder. Talk.
7:30am - Am I ever gonna get started?
8:00am - Fresh cup of coffee. Head outside. 32 degrees. Temp rising, spirits moderate.
8:05am
Tractor tire low. Plug in air compressor. Weird sound. Air compressor needs oil. Locate oil, add.
8:15am - Air compressor did not need oil. Sprayed excess all over carport.
8:30am - Clean up mess. Drag air hose to tractor. 4 feet short. Idea: move tractor 4 feet closer.
8:45am - Jehovah's Witnesses show up.
9:00am - Back at it. Start tractor. Correction: attempt to start tractor. Battery is drained from cold temps.
9:15am - Pull truck up to tractor. Find jumper cables. Found. Realize they're broken.
9:30am - Find other set of jumper cables. Good ones.
9:45am - Hook up cables. Correction: attempt to hook up. Loader is preventing hood from being raised. Try to be a contortionist, unsuccessful.
10:00am - Back inside. Talk. Wife is leaving to go shopping. Gave her all of my money.
10:20am - Post to TBN.
10:37am - What was I going to do today?
   / 8AM Saturday #2
4:30am - Wake up. Not sure why. Start thinking of all the projects I want to work on. Think till 5. 5:30am - Shower took, coffee made. 27 degrees. Temp low, but spirits high. 6:00am - Go outside. 6:03am - Go back inside. 6:05am - Check weather. Hang out on TBN. 6:30am - Little boy wakes up. Pigs n a blanket & chocolate milk. Play dinosaurs & tiger, his rules. 7:00am - Brother shows up to check feeder. Talk. 7:30am - Am I ever gonna get started? 8:00am - Fresh cup of coffee. Head outside. 32 degrees. Temp rising, spirits moderate. 8:05am Tractor tire low. Plug in air compressor. Weird sound. Air compressor needs oil. Locate oil, add. 8:15am - Air compressor did not need oil. Sprayed excess all over carport. 8:30am - Clean up mess. Drag air hose to tractor. 4 feet short. Idea: move tractor 4 feet closer. 8:45am - Jehovah's Witnesses show up. 9:00am - Back at it. Start tractor. Correction: attempt to start tractor. Battery is drained from cold temps. 9:15am - Pull truck up to tractor. Find jumper cables. Found. Realize they're broken. 9:30am - Find other set of jumper cables. Good ones. 9:45am - Hook up cables. Correction: attempt to hook up. Loader is preventing hood from being raised. Try to be a contortionist, unsuccessful. 10:00am - Back inside. Talk. Wife is leaving to go shopping. Gave her all of my money. 10:20am - Post to TBN. 10:37am - What was I going to do today?
Thanks for the chuckles. :)
   / 8AM Saturday #4
Good ole country living. :thumbsup:
   / 8AM Saturday #5
About those trickle charges on tractors that set for a while.......I believe they are a good idea.. I have solar ones on each of mine as there is no AC power in their barns.
Someone once said: "If it has **** or wheels, you are going to have trouble with it!"
   / 8AM Saturday #6
I think that was you James...... ;)
   / 8AM Saturday #7
Makes you wonder what tomorrow is going to bring...
   / 8AM Saturday #8
The best plan is no plan.
I rarely have a plan.
   / 8AM Saturday #10
8:05am
Now that was funny, I have had days like that but there getting rarer, I have just now started to get kinks worked out.
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
UNUSED AGT SA-FT HYD PALLET FORKS (A51248)
UNUSED AGT SA-FT...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
STORAGE FEES (A53426)
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
2025 New/Unused Wolverine Mini Ripper (A51573)
2025 New/Unused...
