8930 turning up the power
   / 8930 turning up the power #1
nigel55
saskatchewan
hi i am very new at this tractor stuff i mainly work on semi trucks but i was wondering if anyone could help me with turning up the power on my 8930 caseih its about 160hp at 2200rpm has the 8.3ltr motor and its a fwa tractor.thanks nigel.
   / 8930 turning up the power #2
Hi, not sure which injection pump is on your machine?? Can u post a couple of photo's of ot ??
   / 8930 turning up the power #3
Should be a Bosch P pump. Remove rear cover use 10mm wrench & screwdriver to adjust max fuel screw. Sorry it's been over 20 years since I "adjusted" one; can't remember if you run it in or out.
BUSH HOG 7007 LOT NUMBER 116 (A53084)
BUSH HOG 7007 LOT...
2024 JOHN DEERE 331P-TIER SKID STEER (A51246)
2024 JOHN DEERE...
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
24ft Gooseneck Trailer (A51572)
24ft Gooseneck...
2021 Fendt 1050 Vario Tractor (A53342)
2021 Fendt 1050...
2002 Mack DM690S Roll Off Truck, VIN # 1M2B209C32M028771 (A51572)
2002 Mack DM690S...
