8870
   / 8870 #1
cooter12
manitoba,canada
john deere
i just picked up a used 8870 , 1995 model , 5300 hours . the crankcase is getting pressure in it . i have removed the breather and it seems fine from the filter out . i.ve thought , maybe head gasket , but when i pull the oil bung after it sitting for 5 or 10 min. and it still has pressure , i have to think it is still a breather issue . has anyone else had this issue . thanks in advance for any help .
   / 8870 #2
If there is still pressure after it is shut off, then there is definitely a breather problem. Are you sure the hose and tube are free and clear? If so then remove the valve cover and check that.
2002 Fleetwood Expedition 36ft Class A Motorhome (A51694)
2002 Fleetwood...
2013 Ford Transit Connect Van (A52377)
2013 Ford Transit...
2020 Ram 1500 4x4 Crew Cab Pickup Truck (A51692)
2020 Ram 1500 4x4...
2015 Dodge Dart Sedan (A51694)
2015 Dodge Dart...
1272 (A50490)
1272 (A50490)
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
