88 Ford 555B - Trans fluid?
   / 88 Ford 555B - Trans fluid? #1
Johnny Glenn
88 Ford 555B
Thanks for looking in - I just purchased an 88 555B and the operators manual lists "Ford 41" for trans fluid - what is a comparable brand or the type of fluid...and where to find? Thanks
   / 88 Ford 555B - Trans fluid? #3
ditto what rickb said. in plain terms.. UTF fluids. available everywhere .. NH dealer, napa, TSC, walmart.. etc. just read the tag looking for M2c134D
soundguy
Thanks - I have some hydraulic fluid from using other machines but don't see a UTF rating on them. Warren 303 Tractor Fluid and Cat 8T-9580 SAE16W- can I use these? When I purchased the 555 the hydraulic level was 5 gallons low - I added the CAT 8T - is that OK or should I drain and refill with UTF fluids? I'm hoping all hydraulic fluids can mix?...but I'm probably wrong? The manual says "Ford 48" for Hydraulic system but "Ford 41" for Transmission?
   / 88 Ford 555B - Trans fluid? #5
UTF is not a rating.. it's a name.. Universal Tractor Fluid.
303 is a very old whale oil standard. checkt he bottle for other standards..
soundguy
   / 88 Ford 555B - Trans fluid? #6
134D i every sump but the engine
2000 Ditch Witch 3700DD Ride-On Trencher (A53421)
2000 Ditch Witch...
Peterbilt (A51692)
Peterbilt (A51692)
Tennant 800 Ride-On Street Sweeper (A53421)
Tennant 800...
STORAGE FEES (A54313)
Kubota ZG327 (A50120)
