87 Ford Aerostar stering wheel
   / 87 Ford Aerostar stering wheel #1
BobReeves
Platinum Member
Tulsa OK
Ford 3000
Friend of mine just gave me an 87 Aerostar mini van I am going to turn into a work van.. Runs great and A/C works but has a few small problems.
One problem is the whole steering head is loose.. I removed the steering wheel and all covers.. Can't see any loose or missing screws but can't really tell how the head attaches to the column. What I am calling the head is the part with the ignition switch, turn signals and tilt mechanism. I have a Clinton manual but it doesn't go into enough detail (typical of these manuals)..
Looks to me like a bracket or clamp may be missing as the rear of the head can be moved side to side and there is a bracket welded to the column close to the rear of the head with nothing attached to it. This van was rear-ended at one time but my friend can't remember if the loose steering head was a result of the accident or not..
Anyone familiar with this minivan that can tell me how the steering head mounts to the column..
   / 87 Ford Aerostar stering wheel #3
Well, I dont have anything that old, but the Ford collumns were pretty much the same for many years.. Although I havent been into one in a while, it sounds like your upper bearings have been beat up.. There is a pretty stout spring in the tilt mechagnisim, so you need to be careful... PM me your e-mail address and I can send you a few pages I think may help..
   / 87 Ford Aerostar stering wheel #4
   / 87 Ford Aerostar stering wheel #5
My 90 aerostar has had a slight bit of side to side movement ( of the whole column) since it was new. That's a 1/4 or a tad more.. It's been apart by a ford mechanic to replace a key cylinder and nothing else was -broke-.. so it is still like that.
Soundguy
   / 87 Ford Aerostar stering wheel #6
Soundguy
Thanks guys, going to be a couple days before I can get back to working on the van and will let you know what I find.
   / 87 Ford Aerostar stering wheel #9
My memory is going but I believe there are 3 recessed (as in 3") torx head screws that are accessible by tilting the column up & down, using a 1/4" drive bit & universal joint. They used to loosen all the time. I remember the job being a pain, but fairly straightforward /forums/images/graemlins/confused.gif
   / 87 Ford Aerostar stering wheel #10
JOHN DEERE 2750 TRACTOR (A54756)
JOHN DEERE 2750...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
2015 Volvo VNL 64T (A55218)
2015 Volvo VNL 64T...
2014 Infiniti QX60 SUV (A53424)
2014 Infiniti QX60...
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
2121 (A51244)
2121 (A51244)
