843 bobcat aux. hyd.
/ 843 bobcat aux. hyd. #1
usmc
asheboro nc
ford 2000
on my 1992 843 bobcat, there are aux. hookups, but no linkages back at the pump. if anybody knows how this system works or what has to be done to make it work please advise.
/ 843 bobcat aux. hyd. #2
It is probably solenoid controlled by switches.
If you don't see any levers, then look for switches. Plug a motor in the AUX and see if any of the switches active the flow.
/ 843 bobcat aux. hyd. #3
843 works with mechanical linkage, move the right hand steering lever side to side to engage front Aux. There is a locking bolt/pin in the linkage behind the steering panel to remove if the lever will not move sideways. Raise the cab and look for a bolt/pin in the linkage going from the lever to the control valve.
