841 stuck
   / 841 stuck #1
mayer2323
My ford 841 is stuck in gear it wont come out. It was somking some after this happened so I stoped and pulled the cover plate . One of the gears was a little chewed up ,
The middle one looked like the biggest too. I always had a problem with 2nd so I thought this might be it but I cant move the gear shift at all.
   / 841 stuck #2
Is it actually hung in 2 gears? IE.. if you let the clutch out she stalls?
Normally if you catchit fast, you can pop the top and jack the wheels up and bar the engine ove rin reverse and pry on the gears and get them apart... but if you already have busted teeth.. plan a fore and aft split..
if you need gears I know a guy that has plenty of salvage parts in good condition.
soundguy
2022 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A52377)
2022 Ford F-250 XL...
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
2003 Ford F-250 Knapheide Service Truck (A51692)
2003 Ford F-250...
2019 Dodge Ram 5500 Tiger Crane 6545EP 6,500lb 3 Ton 4x4 Crane Mechanics Truck (A51692)
2019 Dodge Ram...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A53473)
John Deere 5090E...
