84" rfm for tc29 or tc30?
   / 84" rfm for tc29 or tc30? #1
nhman
Virginia
Kubota B2910
84\" rfm for tc29 or tc30?
Anyone used the tc29 or tc30 hsd to pull a 84" rfm? Is this possible, or does it stress the tractor?
nhman
   / 84" rfm for tc29 or tc30? #2
Re: 84\" rfm for tc29 or tc30?
I don't think you would have the ponies to twist one. Or the ballast to lift and handle one well without a loader bucket full of rocks. No, I haven't tried it, but I do own a Woods RM990 (90") and it is a handful for a good running Ford 841D, both weight wise and in power requirement.
   / 84" rfm for tc29 or tc30? #3
I have a TC29 and are currently pulling a 72" RFM. In my opinion this is the tight pkg for that size of tractor. The only bogging I have ever noticed was on really long uphill stretches, the grass still somewhat wet. weght wise my 600lb mower is a good balnce for the 3pt hitch with or without the FEL. Add the extra 200+ lbs of an 84" mower as well as the longer length and I'm sure it would definitely be out of balance.
   / 84" rfm for tc29 or tc30? #4
Re: 84
I have a TC29 and are currently pulling a 72" RFM. In my opinion this is the tight pkg for that size of tractor. The only bogging I have ever noticed was on really long uphill stretches, the grass still somewhat wet. I think the power demands of an 84" mower would be to much for the TC29/TC30 or even the TC33. Weght wise my 600lb mower is a good balnce for the 3pt hitch with or without the FEL. Add the extra 200+ lbs of an 84" mower as well as the longer length and I'm sure it would definitely be out of balance.
   / 84" rfm for tc29 or tc30? #5
I think it would depend on your terrain. My TC29D handles a 6' mower with no problem, even on hills. I can mow some pretty thick grass in mid range and full speed on the hydro pedal on level ground or slight inclines. But, it will not maintain full PTO speed on a long uphill grade unless I back off on the hydro pedal. Also, the balance is good and I can go up a 20 degree hill without the front coming up (I don't have a FEL and I have 2 of the small weights on the front, which I think is about 75lb). I'm sure a 84" mower would require much more weight to balance. On flat ground you should have the power, but hill might be a problem.
   / 84" rfm for tc29 or tc30? #6
Re: 84
I think that unless you are planning on only trimming an inch or so at a time with something this big, you're otherwise really stretching things. Back down to a 72" and I think you'd be safe. I used a 72" behind my old 1720 for years and always felt it was the right size. Sometime I had to slow down the ground speed going up long hills or in heavy grass, but otherwise it was OK. To me, a 84" deck is just too big behind a mid-size machine like you're proposing.
2011 Ford Transit Connect XLT Cargo Van (A50323)
2011 Ford Transit...
2005 Wilson Hopper Bottom Trailer (A50514)
2005 Wilson Hopper...
2015 Chevrolet Express 4500 Shuttle Bus (A50323)
2015 Chevrolet...
E-Z Trail 675 Grain Cart (A50514)
E-Z Trail 675...
