Rotary Cutter 8' Land Pride
   / 8' Land Pride #1
nckennedy
Camillus, NY, USA
JD 5425
Leaving a section of grass uncut in the middle of swath. Any suggestions?
   / 8' Land Pride #2
Are you turning it at PTO speed?
Slow down and or sharpen the blades.
SR
   / 8' Land Pride #3
bent blades will cut like that as well
   / 8' Land Pride #4
I have reasonably sharp blades. Slowing down improves two things - the ride and the cut.
   / 8' Land Pride #5
What model Landpride rotary cutter do you own? Are all 3 blades gear driven, or does it use a belt?
I have a Landpride FDR2584 and if the belt tension isn't set correctly, the center blade doesn't cut properly. The center spindle pulley has the least amount of belt - pulley contact, and is prone to slippage.
2019 KENWORTH T880(INOPERABLE) (A48992)
2019 KENWORTH...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A48836)
IMPORTANT PLEASE...
2007 International 7500 sba Flatbed 6x6 Truck (A47371)
2007 International...
JD 772-A Grader  (A47371)
JD 772-A Grader...
MISC SUBS (A48992)
MISC SUBS (A48992)
60" Pallet Forks, New (A47371)
60" Pallet Forks...
