pclausen
Veteran Member
I have a low hour (~60 hours) 7Iron deck that keep popping the tire from the left front caster wheel. Here's the wheel/tire in question:
Closeup:
Its mounted to a 1445 as seen here:
This is an older setup (2002 I think) but as stated above, this entire rig only has about 60 hours on it. The tire has popped off the rim about 4 times in the last 20 hours of using it. Each time I have carefully cleaned the wheel and the area of the tire that contacts the wheel. Is there perhaps a newer design tire/wheel available that doesn't have this problem? I'm not cutting rough stuff, just a regular lawn (1 acre or so) that's pretty level.
Closeup:
