78" Dozer Blade
   / 78" Dozer Blade #1
Bob_Bullock
78\" Dozer Blade
I came across the blade below on Ebay. I have been trying to figure out if I wanted a FEL snow blade with a quick connects or a separate dozer/snow blade. I want to use it for snow removal and light grading work.
Here is the listing....
YOU ARE BIDDING ON A 78 INCH BLADE
Snow/Front/Dozer Blade
Compatible with: New Holland TC29DA, TC30 & TC33DA
(Includes hydraulic valve)
This blade angles right, left and lifts up and down
Good looking blade with skid shoes and spring back
I have some questions?
1) Will this work with my TC33D?
2) I have a mid-mount mower, do I keep that hardware on along with the FEL and the snow blade? How would all that work.
3) Assuming it would work, what are the advantages to have this type of blade versus one that goes on the FEL? I know using the quick connects you could change over quickly. I have taken my FEL of plenty of times and that is quite easy also. How hard would it be to change over to the snow blade versus quick connects?
The person selling this said since I have a FEL (7308) that I wouldn't need the valve so I could take $400 of. That makes it $1800 versus $3000 I am getting quoted for quick connects and a snow blade for my FEL.
I welcome any insights you guys can give me.
   / 78" Dozer Blade #2
Re: 78\" Dozer Blade
Email the seller on ebay. Bob
   / 78" Dozer Blade #3
If that's the blade I'm thinking of, it mounts on a separate front subframe which will also work with the front broom, front snowblower, and so on. The two motions your valve will impart are up-down to a limited extent (compared to the FEL) and left-right angling. I don't think it does anything resembling dump or rollback motion.
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A52576)
2020 INTERNATIONAL...
BUYER'S PREMIUM INFO LOT NUMBER 2 (A53084)
BUYER'S PREMIUM...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2016 FREIGHTLINER...
2015 KENWORTH T800 (A52472)
2015 KENWORTH T800...
2013 FREIGHTLINER M2 TANDEM AXLE DAY CAB (A52576)
2013 FREIGHTLINER...
