7740 tach
   / 7740 tach #1
Farmcooky
I have a probler with the rpm tach on my 7740 some times it works and some times it does not
   / 7740 tach #2
sounds like your tach needs replacing.
   / 7740 tach
RickB said:
Or the wiring between the alternator and tach. Next time the tach quits, see if the PTO works. If the PTO relay doesn't get a 'W' (AC) signal from the alternator, the PTO is inoperative. Same signal drives the tach.
The pto works cuz I was baling when the tach wasn't working
1995 Mazak VTC-16B Vertical Traveling Column Machining Center (A51691)
1995 Mazak VTC-16B...
2020 CASE 580N EP BACKHOE (A51246)
2020 CASE 580N EP...
2006 SCHWING P-88 PORTABLE CONCRETE MIXER (A51247)
2006 SCHWING P-88...
2019 CATERPILLAR 316FL EXCAVATOR (A51246)
2019 CATERPILLAR...
2022 MGT CM11CUFT S/A Towable Concrete Mixer (A51691)
2022 MGT CM11CUFT...
