770B replacement valve assembly with single joystick
   / 770B replacement valve assembly with single joystick #1
59overlander
1910 ford 4x4
I purchased a Ford 1910 4x4 in very good condition but the 770B loader valve is worn out. I plan to purchase a new single joystick 2 spool valve with float and power beyond, but I want to know if anyone out there has done this before. I would like to purchase this from Surplus Center, but I need a Prince part # if possible, to eliminate the hassles of picking the wrong one. Thanks
   / 770B replacement valve assembly with single joystick #2
Wondering if you might just buy this:
   / 770B replacement valve assembly with single joystick #3
Many have recommended the Prince RD522GCGA5A4B for setups like yours works well with loaders and includes the float feature. Surplus Western Center should have it, but double-check compatibility to be sure. Good luck with the install.
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
UNUSED Brown Metal Roof Wall Panels (A50860)
UNUSED Brown Metal...
New/Unused 20ft Farm Metal Driveway Gate (A48837)
New/Unused 20ft...
2015 Ford Explorer SUV (A48082)
2015 Ford Explorer...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
