7610-S pto question
   / 7610-S pto question #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Ok,, I found the yellow pto engage/disengage lever by my left foot.. now what determines whether it is 540 or 1000 rpm pto?
Does the tranny hi/lo selector bump the pto up as well?? Or is their another lever.
Also... I'm guessing this unit is a independent pto... and not a 2 stage clutch. If so.. is their any way to 'easilly engage' the pto.. so that it doesn't shock load up at the moment it is engaged?
thanks
Soundguy
2018 FORD F-150 XL EXTENDED CAB TRUCK (A59823)
2018 FORD F-150 XL...
2001 CATERPILLAR CB-634C SMOOTH DBL DRUM ROLLER (A60429)
2001 CATERPILLAR...
2015 Goose Neck Cattle Trailer (A53317)
2015 Goose Neck...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 Toro Sand Pro 5040 Bunker Rake (A59228)
2017 Toro Sand Pro...
1981 Kari Kool 6,500 Gallon T/A Tanker Trailer (A59230)
1981 Kari Kool...
