Backhoe 757C Hydraulic pressure relief?
   / 757C Hydraulic pressure relief? #1
treefarmer391
We run a firewood and XMAS tree farm in NE CT using a TC30 with many attachments (FEL,BH,LP mainframe with rear blade,rake,scarifier,rotary cutter,Wallenstein chipper). Run into a problem where the BH was taken off and having problems reconnecting. Done this many times over the years without problems, but think the hydraulic pressure was not relieved before disconnecting and cannot get the hoses reconnected.
Factory service manuals don't show any pressure relief/poppet valve other than for the max pressure.
Anyone run into this before? Any ideas?
Thanx
Cedar Brook Farm
   / 757C Hydraulic pressure relief? #2
if you aren,t able to get the ball in coupler to relieve pressure you always have the option of cracking the nut lose on the metal line and get pressure off that way:thumbsup:Dave
Released pressure at the outlet valve spool reservoir fitting after removing the cowl. Hoses reconnected and BH re-attached without problems.
As an FYI, the local NH dealer had no clue, but was more than willing to make a service call....(-:
Thanx Dave.
2023 John Deere 6155M MFWD Tractor (A53342)
2023 John Deere...
100 GAL FUEL TANK W/PUMP (A52472)
100 GAL FUEL TANK...
20 Yard Rolloff Container (A51573)
20 Yard Rolloff...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2017 FREIGHTLINER...
2023 Yamaha YXZ 100R SS (A51573)
2023 Yamaha YXZ...
