756C curl issue.
   / 756C curl issue. #1
Fcz23
Ford 1720
The curl on my hoe is weak, slow, and actually will not curl unless I pull the lever back to also drag the arm and boom. If if curl everything up in order to trailer the machine, the bucket will sometimes just slowly uncurl and can be moved by hand.
I broke the cardinal rule and lent the machine to someone that operates; and got it back like this. It may have been pushed a little too hard?
   / 756C curl issue. #2
Might have blown the piston seal in that cylinder. Maybe time for a repack job.
   / 756C curl issue. #3
Read and/or watch a youtube video on how to test a hydraulic cylinder.
I suspect wdchyd is right and you have all the symptoms of blown seals in the curl cylinder.
Fifth wheel multi use trailer. (A53472)
Fifth wheel multi...
2012 JOHN DEERE 410K BACKHOE (A51406)
2012 JOHN DEERE...
1273 (A50490)
1273 (A50490)
2004 PROCO 130 BBL VACUUM TANK TRAILER (A52472)
2004 PROCO 130 BBL...
2025 New/Unused Wolverine Hydraulic Skid Steer Pallet Forks (A51573)
2025 New/Unused...
28013 (A50322)
28013 (A50322)
