Mike,
Yes - I considered those two, plus the NH TC21D and the Kubota
B2410. All of them are almost identical in physical size. Between the
B7500 and the 4100, the 4100 wins out in hydraulic pump capacity, loader lift capacity, and in overall ease of implement attachment/detachment (I think the last one is a very narrow advantage). Also, the 4100 has 3ph position control while the
B7500 does not. The
B7500 wins out in 3PH lift capacity and in engine horsepower. I also believe the Kubota engine and drivetrain are a bit smoother than the Yanmar. Around here the
B7500 would be about $1500 or so cheaper than the 4100.
With all that said, your own preference that develops when you drive each will probably outweigh any of the above 'specs'. There is also a lot of discussion in the archives that you can tap into - these two tractors have been discussed and compared quite a bit.
Hope that helps. Welcome aboard.
Rob
<P ID="edit"><FONT SIZE=-1>
Edited by Wheeldog on 09/25/01 08:06 PM (server time).</FONT></P>
