743 bob cat
/ 743 bob cat #1
venice
Lisbon,OHIO
743 BOB CAT
WHAT DO I REMOVE TO GET TO A HYDRAWLIC LINE LEAK UNDER THE FLOOR IN FRONT OF THE SEAT ? THE LEAK FLOWS OUT UNDER THE PLATE BETWEEN THE FEET AND TO THE FRONT.
I SEE TO BOLTS TOWARD THE FRONT BUT NONE IN THE REAR .
/ 743 bob cat #2
There are (2) 1/2"bolts at the front corners of the ROPS/cab, remove the nuts then push up on front of the ROPS. It is hinged at the back so it tilts up. Use caution, there a gas strut to help raise and it is "supposed" to have a hold catch on it to hold the ROPS up but many of these get broken off so ROPS could fall back down. Safer way is use a ratchet strap hook at front top of the ROPS over the ROPS and hooked to frame of engine compartment to hold it up.
