Tiller 74" Rock finding attachment (i.e. tiller)
   / 74" Rock finding attachment (i.e. tiller) #1
grandad
Platinum Member
Greensboro, North Carolina
Kubota L4610, BX2230
74\" Rock finding attachment (i.e. tiller)
Just tilled 2+ acres for the first time... every 25 ft, hit a grapefruit-size or larger rock that momentarily jammed the tiller. The old slip clutch got a real workout. Eventually I got the hang of popping the clutch, raising the 3-point and re-engaging the clutch- which would chuck the offending nugget loose. Most of 'em went back under - good for mowing, bad when we work the ground again.
I don't even want to think about what a shear-pin tiller would have been like on that 2 or so achers. That's a hint for those considering a tiller. Unless you are REALLY sure there are no rocks down there, get one with a good slip clutch.
Fortunately, job is done, nice and smooth, seed & fertilizer down and no broken tines. Maybe with some rain, pasture will take hold and we won't have to go rock hunting here again for a while.
   / 74" Rock finding attachment (i.e. tiller) #2
Re: 74
Sometimes I believe the tillers are rock planters. Everytime I till I pick up the exposed rocks as I go along. The next year a whole new crop has grown. Unfortunately I break many tines. Fortunetly the gound has been tilled enough so the slip clutch will now work. I have also removed half the tines to make it easier on the chain drive and gearbox.
Egon
John Deere 652R (A50121)
John Deere 652R...
Mini Excavator Attachment Set (A50121)
Mini Excavator...
2020 KUBOTA RTV...
Chemical Tank & Pump (A50121)
Chemical Tank &...
2019 International DuraStar 4300 2,000 Gallon Water Truck (A50323)
2019 International...
2013 FREIGHTLINER CASCADIA 125 DAY CAB (A52141)
2013 FREIGHTLINER...
