74 Ford 2000 series gas tractor- Replacing Clutch
   / 74 Ford 2000 series gas tractor- Replacing Clutch #1
Howard707
Chesapeake, VA
Ford
Hi folks, I am replacing the clutch, pressure plate and throw-out bearing on my gasoline 74 Ford 2000 series tractor. I have the service manual, however, it does not explain how to remove the hydraulic pump. It has 2 lines that go the length of the tractor and I am not sure how to remove this safely. It has to be removed to split the tractor in half. Is there anyone out there that has done this before or possibly anyone with more detailed instructions on how to replace the clutch in my tractor? Any help would be greatly appreciated! Any tips or anywhere online that you can send me would be great too!!!
   / 74 Ford 2000 series gas tractor- Replacing Clutch #2
You are more likely to get a response in the New Holland forum owner/operator sub-forum.
New Power Line 400 Plastic 3pt. Spin Spreader (A50774)
New Power Line 400...
1994 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A49461)
1994 Mack CH613...
PALLET OF HYDRAULIC HOSES (A50854)
PALLET OF...
197637 (A50459)
197637 (A50459)
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
