Backhoe 74 case 580b
   / 74 case 580b #1
deadcntr
case 580b
this is a diesel engine. how do i relieve pressure on a cylinder that i think has water in it from the cover of the muffler being left off. has sat for 6 months. and just bought it and cant seem to get engine to turn over.. starter and cylinoid have been checked and are working.. does this have a glow plug or a block heater.
   / 74 case 580b #2
I don't know anything about your tractor, but would expect you can remove injectors from head and turn it over to blow water out..??
   / 74 case 580b #3
Like Hawkeye08 said, removal of the injectors would be the easiest, other than removing the head. The 580B's did not have glow plugs. They had 3 options for cold weather starting. A block heater, a manifold heater, and a ether injection system, into the intake manifold.
Here is a link, to Case Construction online parts store, already set to the 580B. Save it to your favorites, I'm sure it will come in handy. Official Case Construction Equipment Online Parts Store and Parts Look Up. Parts for Case Equipment and Construction Equipment. Parts Store for Case Wheel Loaders, Case Excavators, Case Skid Steers, Case Original Parts. If you've never had a piece of Case Equipment, you'll soon find that they were great at changing parts, at certain serial number breaks. So you definitely want to find the serial number on that hoe, to help you find the correct parts.
If for some reason you would happen to need any parts, you can select a local dealer, then you can check prices on said part. You can also copy and paste the part number listed on these pages of the parts store, to a good search engine, and compare prices on aftermarket parts. I use Google. I've found in the past, some parts are dealer only, and also used on Case/IH Ag. tractors. Those parts through an Ag. dealer usually run 10% less than through Case Construction. I usually use Messicks Case/IH Ag. dealer, to see if parts are used on Ag. tractors.Messicks | Your home for New Holland, Case IH, Kubota & More... There are very few dealer only parts anymore. Searching, using the part number is the easiest way I have found, to get the exact part you're looking for. There are a few dealers out there, that handle NOS parts, along with their aftermarket lines.
   / 74 case 580b #4
YUP.. pulling the injectors..
U DONT want to hit that starter or you'll be buying afew parts before she even starts..
I think your machine has "pencil" injectors.. Theres a special puller for them.. its a lot easier than using a screwdriver & vise grips..
The tool is around 120.00 but well worth the $$.
ALL SORTS of engine manuf. use pencil type injectors so if u find a good deal on the puller on the JD website, its ok..
As long as your ordering parts.. get an exhaust "FLAPPER" to bolt on the stack..
Good luck & lemme know if u need pump or injector help.. TPG
   / 74 case 580b
thank you very much for the info. ill try it in the am..
   / 74 case 580b
thank you for the info. going to give it a shot in the am..
   / 74 case 580b
thanks alot for the help guys... like is said trying it in the am before the rain comes in.. i made sure to cover the stack. the previous owner had left it uncovered..
UNUSED MOWER KING SSEFGC175 HD FLAIL MOWER (A51244)
UNUSED MOWER KING...
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
NEW 2024 LOAD TRAIL 83IN X 14FT Tandem Axle Dump Low-pro Trailer (A52128)
NEW 2024 LOAD...
UNUSED AGT SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SAII100...
2008 Ford F-250 Reading Service Truck (A50323)
2008 Ford F-250...
CATERPILLAR D6R XL CRAWLER DOZER (A51242)
CATERPILLAR D6R XL...
