7308 loader ????
   / 7308 loader ???? #1
Anonymous Poster
Epic Contributor
I understand that the 7308 is the perfect match for the tc-30. What about a rhino fel, i understand it is the same product and make as the n//h ???
Is this a bad move, I have just about ordered to tc-30
thanks joe b.
   / 7308 loader ???? #2
Joeberry:
I'd stick with NH factory loader. If you have a loader problem NH won't be able to point there finger at the loader and have you running around town or spending your time on the 1-800 please help me line.
Whiskey
   / 7308 loader ???? #3
My advice is to stick with the New Holland 7308 and order it with the tractor so you'll get a better price. It will cost a lot more if you add it later. After market loaders are not designed for a specific tractor, they are made to fit a wide range of tractor brands and models, so there are drawbacks. As for the Rhino, unless you actually see one in person, don't trust what anybody tells you! I suggest you read the following threads:
Ordered my Bush Hog M246 FEL
When is rear ballast needed with a FEL?
   / 7308 loader ???? #4
Joe,
Whenever you can I would stick with the Manufactures attachments. When there is trouble there is only one company to look to. If you have another brand on there it is so easy for one or the other to blame the problems on the other and you sit in the middle of it..
Also I am not sure you get the Joystick on the fender with the Rhino brand. And that is a nice feature if you ask me.
murph
   / 7308 loader ???? #5
Danny,
How do you insert past posts in your post? I have tried that before but can't seem to figure it out. I know if I would spend some time figureing I would get it, but if someone could tell me it would be great also.
murph
   / 7308 loader ???? #6
murph - Do like below, but use "[" and "]" in place of where I have "{" and "}":
{url=http://www.tractorbynet.com/forums/newreply.php?Cat=&Board=buynh&Number=279322&page=0&view=collapsed&what=showflat&sb=5&o=186&fpart=1&vc=1}title of thread goes here{/url}
   / 7308 loader ????
Here's how I do it. It comes out looking like Danny's example.
Any time, you don't understand anything I'm saying, just ask. I start a reply message, then realize I want to post a link to a previous message. I don't want to lose my place, so I open a second instance of my browser, navigate to TBN. Now I have 2 copies of TBN open. I navigate to the post I want to paste, click on the browser's address box to highlight it, and click ^C (cntrl + c) to copy it. You could close the 2nd instance now, you're done with it. I then click back to the reply message, and click the "URL" tag in the Instant Markup section under the reply. That brings up a text box which already has "http://" in it. I click in that box, which highlights the stuff already there, which will get replaced when I paste. I then click ^V to paste and hit ENTER. That brings up a second text box where you can type in a shortcut "title" for the link. Hit ENTER again, and the link is inserted in your reply.
It still looks like gobbledygook, so when your message is done and you click "Continue", be sure to scroll up and preview your link to see if it looks OK. The click to submit your reply. Being basically paranoid, at this point I usually go to my message and test the link to make sure I did it right. If I screwed up, I use the "Edit" feature and try to repair it, byu deleting the link and starting all over again. Using the copy and paste method, though, it almost always works.
Good luck.
PS: Ever wonder how ^V got to be the symbol for paste? Way back in the early days of personal computers, the first really successful word processing program was WordStar. They used a lot of control keys (no mouses yet). They stayed away from function keys, like some of the others used, because it was harder to remember which F-key did what. Instead, as much as possible, they used mnemonics to remember the control keys. ^C for "Copy" was obvious. But, with only 26 letters and a lot of functions, they had to get a little more devious. So, ^X became "Cut", based on 2 theories -- you were "Xing out" the text being cut, but the actual truth was that to the programmers, an "X" reminded them of scissors. As for the ^V, if you remember back to the days of typewriters and handwriting, when you edited a draft, and realized you wanted to insert something, you either used a caret "^" or a reverse caret "v" to indicate where you wanted the insert to go. Since with computers the caret ^ already was shorthand for the CNTRL key, that left the "v" to indicate an insert - which is what happens when you paste something. WordStar was so widespread it became the defacto standard and is still used today.
More useless knowledge dredged from the so-called brain of a nerd... /forums/images/graemlins/crazy.gif
   / 7308 loader ???? #8
<font color="blue">...WordStar was so widespread it became the defacto standard and is still used today... </font>
Hi Don,
Wordstar had the tiger by the tail... but when Windows came along... they dragged their feet... sooooooooooo long... it lost its market share and died...
I used Wordstar for a couple years with CP/M... and a year or two with DOS until Windows was released... but still use most of their shortcuts... cause everyone else "copied" them to be compatible... /forums/images/graemlins/smile.gif
   / 7308 loader ???? #9
</font><font color="blue" class="small">( I usually go to my message and test the link to make sure I did it right )</font>
Me, too. In fact, I test the link on the preview screeen before I hit that final "Continue" to post the message. But I never got accustomed to using the Ctrl key, carets, and other symbols. I just use the Alt key and correct letter from the menu at the top, or click on the one I want. /forums/images/graemlins/grin.gif
</font><font color="blue" class="small">( WordStar was so widespread )</font>
When I went to the FBI National Academy I took my own old Radio Shack computer and printer to do my paperwork in my room, but they had a room set up with 31 PCs for the students to use, and they used WordStar, which wasn't what I was using for a word processor. We were split up into "sections" of 50 people in each section, and someone got the erroneous idea that I knew something about computers (a lot of the guys had never used one), so I got appointed as the "computer liaison" for my section; i.e., anyone who had a problem outside normal classroom hours was supposed to come get me to help. /forums/images/graemlins/shocked.gif Talk about the blind leading the blind. /forums/images/graemlins/blush.gif So I learned WordStar (pretty good program), but then after that 10 weeks, I never saw it again. /forums/images/graemlins/laugh.gif
   / 7308 loader ???? #10
I also remember Wordstar. It's amazing and sad that MS hasn't done away with the Ctrl-C, Ctrl-V, etc. UNIX Workstation keyboards have "Cut", "Paste", etc keys on the keyboard. MS needs to get with it!
I use a freebe I got off the web, My Function Keys and I love it. If you want to pay for it, it will let you program all the keys. It's easy to turn off if it interferes with anything.
UNUSED SDLANCH SDLGC ELECTRIC GOLFCART (A54756)
UNUSED SDLANCH...
2007 Ford F-150 Crew Cab Pickup Truck (A55788)
2007 Ford F-150...
TORO MBTX2500 STAND ON DUMP BUGGY (A52705)
TORO MBTX2500...
2016 CATERPILLAR 259D SKID STEER (A52705)
2016 CATERPILLAR...
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
2016 Ford E-450 LP Handicapped Bus (A55788)
2016 Ford E-450 LP...
