730 wiring
   / 730 wiring #1
mwh0428
Can anyone help me out with this? We put a new wiring harness on our 730 diesel electric start. We got the harness from agri-services out of Alden, new York. We have everything hooked up but the circuit breaker keeps popping whenever we go to try and start it. It will allow the starter to turn then it will pop. We have gone over the diagram that came with the harness and in the IT book we have. The lights work so we know we have power. Anything to check electrical isn't quite my area of expertise, especially when it's positive ground and both 12 and 24 volt.
   / 730 wiring #2
Technically JD 24 volt starting & charging circuits aren't supposed to be "grounded". Yes the accessory circuits are either 12+ or 12- ground. Can you post a photo of the Agri-services 24V wiring harness?
   / 730 wiring #3
I got all excited about helping since our 530 is still OEM 12 volt wiring....and no problems. But then saw yours was 24 v. diesel.
Does the 730 have all the "modern features" like the 530s got?
rScotty
   / 730 wiring #4
rScotty
Other than a bastard electrical system, yes. I had a pony start 730 for a number of years, it was a beast.
   / 730 wiring #5
rScotty
JD 530 & 730 tractors share the same options except the tractors smaller than 730 weren't offered with diesel engine that utilized a starting engine or 24 volt starter.
   / 730 wiring #6
Sounds like you might have a short to ground in the starter solenoid, or the circuit breaker may be bad. Assuming the wiring is correct. Has starter been rebuilt? If it has, Hopefully someone familiar with the JD "insulated" ground 24 volt systems did the work on it. There are peculiarities that can cause shorts if someone unfamiliar works on them.
JOHN DEERE XUV590M (A53084)
JOHN DEERE XUV590M...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
UNUSED WOLVERINE SBM-12-72W-72" HYD SICLKE BAR (A51248)
UNUSED WOLVERINE...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2017 Vicon 764 (A50123)
2017 Vicon 764...
2016 Kubota RTV-X900 4x4 Utility Cart (A51691)
2016 Kubota...
