jreed735
I have a Case 450 dozer and when I first start the machine the right side drive is a little slow to react (takes about a second to respond) but the left side reacts immediately. Then after using the machine for about 20 min the right side slowly goes out. I can engage the drive and rev machine and it will start working for approx. 5 more min then goes out completely. The left side always works perfect. if I let the machine sit over night it is fine at first then the same issue. If I pull the lines off the valve body the line for the left side sprays out with pressure and the right side just runs out nice and slow like a garden hose. I have the valve body off now checking for cracks or leaks but all looks ok. Any help would be great. Thanks
