72" RFM questions
   / 72" RFM questions #1
Anonymous Poster
Epic Contributor
72\" RFM questions
Must admit I didn't do my homework very well. The Frontier finish mower which I purchased, has spacers on all four float wheels which must be moved to change the cut height. Is this the way most/all RFMs are? Any secrets as to how to best use the RFM, full float on the wheels?
   / 72" RFM questions #2
Re: 72\" RFM questions
My Bush Hog finish mower also had the spacers for all 4 wheels and, yes, I mowed with the mower in full float; just riding on those 4 wheels.
   / 72" RFM questions #3
All of the RFM I've seen (LandPride, Woods, Bush Hog, KingKutter, Caroni, and a few others) have the spacers for adjusting the height, so I'm guessing that's they way they all do it. It can be a pain if you change the height often. Fortunately for me, I don't change the height very often. I almost always run the mower with it riding on all four caster wheels. Occasionally, I'll raise it up with 3pt to get over a hump or something.
   / 72" RFM questions
I use mine full float. It has the spacers and I have it set all the way up. It'll scalp the ground over a hump but I figure that I'll drag those areas down with the grader and once they have grown over it'll make a smoother lawn.
   / 72" RFM questions
The bigger the mower deck, the more scalping. It is inevitable.
Just smooth out the scalped spots until you have a nice even cut.
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
2025 SDLANCH SDLGC80 UNUSED Electric Golf Cart (A53117)
2025 SDLANCH...
2011 New Holland Boomer 90 MFWD Utility Tractor (A53473)
2011 New Holland...
2007 Toyota Tundra 4WD Pickup Truck (A53117)
2007 Toyota Tundra...
2013 Toro Workman HDX Scissor Lift Utility Cart (A51691)
2013 Toro Workman...
