72" EA Brush Cutter*Check Your Shaft*
   / 72" EA Brush Cutter*Check Your Shaft* #1
EverythingAttachments
Elite Member
Newton NC
Which One do you want to know about?
A few months ago, EA made some staff changes in the final assembly department, which apparently resulted in some 72" rotary cutters going out with the wrong length PTO shafts.
If you have a 72" EA brush cutter, please check the COLLAPSED OVERALL length of the shaft.
If it is 46" overall, the shaft is incorrect.
The shaft should measure 54" overall.
If you have the incorrect shaft, we will send the correct one to you ASAP.
Travis
71060 (A49346)
71060 (A49346)
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER TRUCK (A51222)
2019 INTERNATIONAL...
2013 Ford F-250 Ext. Cab Pickup Truck (A50323)
2013 Ford F-250...
2016 CATERPILLAR 336FL EXCAVATOR (A51242)
2016 CATERPILLAR...
2007 MACK VISION (A50854)
2007 MACK VISION...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
