71 ford 3000 hydrolic screen filter
   / 71 ford 3000 hydrolic screen filter #1
dford
north IDAHO
TC 35D 2001, 16LA,
How do you get the sreen filter out, located in rear differental. Tube goes under PTO shaft turns and back against rear of housing, support arm is bolted to bearing plate, removed support bolt and ? to remove.
   / 71 ford 3000 hydrolic screen filter #2
The PTO shaft must be removed. It is also easier if the hitch cover is removed, you can then change the return filter as well.
CATALOG IS A GUIDE ONLY!! (A50775)
CATALOG IS A GUIDE...
2017 TRAILSTAR END DUMP TRAILER (A50854)
2017 TRAILSTAR END...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2012 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2012 GENIE...
2010 L3 GENERATOR SET (A51222)
2010 L3 GENERATOR...
KOMATSU PC130-8 EXCAVATOR (A50854)
KOMATSU PC130-8...
