'71 2000 lift arm length
   / '71 2000 lift arm length #1
dawzie
Bronze Member
Marlboro,NY
'50 8N, '67 & '71 ford 2000, 2010 Bobcat CT-235 TLB
I'm having problems with tractor supply parts. I have a '71 2000, and think the factory lift arm length is 32" center ball to center ball. Tractor supply arms are 32 1/2", the stabilizer arms from them are 31 9/16" W.T.F. ?
My lift arms are badly worn. I have been using there stabilizers with no problem but if I put on their new lift arms I don't see how they can work.
Any thoughts on my problem?
Things I thought as options
#1 - shorten new arms to 32"
#2 - make new stabilizers 32 1/2" long
#3 - leave the old worn out stuff on (lol)
Also on the new lift arms the linkage connect holes are drilled in a slightly different place. Will cause linkage to be connected 1" closer or farther away. Farther causes more lift power, less height, opposite for closer.
dawzie
WESSEX RMX500 LOT NUMBER 45 (A53084)
WESSEX RMX500 LOT...
20 Yard Rolloff Container (A51573)
20 Yard Rolloff...
1993 INTERNATIONAL 9700 TANDEM AXLE CAB OVER (A52577)
1993 INTERNATIONAL...
2021 CATERPILLAR 289D3 SKID STEER (A51246)
2021 CATERPILLAR...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
1988 John Deere 310C Backhoe (A52384)
1988 John Deere...
