70a loader question
   / 70a loader question #1
855Idiot
Bronze Member
Salt Lake City, Utah
John Deere 855
I have a 1995 JD855 with a 70a loader.
When I lower the loader I can hear a hiss/noise on one side?
The other side is quiet.
The noise is similar to water flowing past a valve as you close the valve?
Any ideas what might cause this noise?
Is it a seal?
Is there air in the line?
No real leaks on this baby.
I searched but didn't find anything.
Remember, I'm an Idiot!
Thanks,
   / 70a loader question #2
It's a normal sound. There is a restrictor on the "lower" side so the loader falls at a controlled rate, you are hearing the fluid being forced through that restrictor.
2020 KENWORTH W990 TRI AXLE DUMP TRUCK (A54607)
2020 KENWORTH W990...
2016 Isuzu NPR Landscape Dump Truck (A51692)
2016 Isuzu NPR...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A55788)
2009 Peterbilt 384...
2016 Ford Fusion S Sedan (A55758)
2016 Ford Fusion S...
2021 CATERPILLAR TL943D TELESCOPIC FORKLIFT (A52705)
2021 CATERPILLAR...
2005 V.E. ENTERISES 130 BBL STEEL VACUUM TRAILER (A53843)
2005 V.E...
