7014 rod
   / 7014 rod #1
rmully
North Carolina
YM 2020
Anyone using 7014 rod? I am thinking of using it over the top of an ugly 6011 weld. Seems like it would make a pretty bead and already have the strength of the 6011. Tried 7018 at 90 amps but it is difficult to use and I need more practice. Welder is an Everlast 200ST
   / 7014 rod #2
I find 7018 a great rod to use. Not a great fan of 7014 but it does lay a pretty nice bead.
6011 has less "strength" than the 70XX rods. With that machine why not use 6010 instead?
Of course that assumes that you have proper penetration and a good weld and are comparing good welds to good welds.
A good weld with 60xx is stronger than a junk weld with 70xx rods.
What diameter 7018 were you running at 90 amps? If using 1/8" that is way low on amps.
   / 7014 rod #3
Furu, I have the 200ST as well and it runs WAY hot as well. 1/8 rod I run between 60 and 80 amps depending on the steel. You have that 300, right?
   / 7014 rod #4
I've used 7014 for 95% of my welding for the past 30+ years. Someone will have to pry it out of my hands when I'm dead. Never had a failure with it. Not good for welding high carbon or alloy steels though. Not the best for vertical welds, I use 6011 for that.
   / 7014 rod #5
7014's are great, drag the flux right on the plate and take a nap :D
The flux makes a cup that sets the arc gap for you - if you have to run a gap, then the amps are too low.
   / 7014 rod #6
Don't know what size of rod you were using but even still, you can't go by what the dial on the machine says. Your machine should burn 7018 fine.
   / 7014 rod
I was using 3/32 7018 rod. I am building a wood stove so there is no a lot of stress on the joints. I just got back from Northern Tools and bought a box of 7014 so I will try it out tomorrow. My problem with 7018 is getting it to flow right... I need to practice more. What amp setting would be good for 7018. I was so interested in the 7018 because the rods need an oven to keep, at least that is what I read.
   / 7014 rod #8
For mild steel welding, 7018 do not need an oven. Mild steel is not susceptible to hydrogen assisted cracking (there are other names for it too).
However, they do run really nice just out of the oven :)
Personal preference for 7018
3/32" 100 amps (plus or minus 5)
1/8" 110 to 135 amps depending on thickness, postion, and weld type
   / 7014 rod #9
I think your 90 amps is pretty darn close for 3/32 7018. I have been down as low as 80 and end up a bit cold and as high as 95-100 amps. I prefer it out of the oven as I like how it flows and the slag just curls off but can be used just fine having never seen an oven. Not doing code work, no requirement, just technique and individual taste.
I am still in my infancy as to welding
   / 7014 rod #10
Wow 1/8" 7018 between 60-80.
I have run 1/8 6010 at 85 and very rarely 75 but not 7018 1/8 inch. If it works and your are getting a good weld then it is what it is.
I have a Longevity 250 and the Everlast 300. I had to have my Longevity replaced at the 1 year point as it was having major problems. It seemed that it was starting to go down the same road again so when the 300 deal popped up I chose to get one at that price as I did not know if the Longevity would hold on without failing again. Really like the Everlast 300.
2022 Caterpillar 310 Midi Excavator (A51691)
2022 Caterpillar...
2017 Ford 550 XL, Cab and Chassis, Crew Cab (A52384)
2017 Ford 550 XL...
2001 Chevrolet Suburban SUV (A51694)
2001 Chevrolet...
2025 SDLANCH SDLE20 UNUSED Mini Excavator (A53117)
2025 SDLANCH...
Coleman 274BH Lantern Edition Travel Trailer (A51694)
Coleman 274BH...
2018 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2018 John Deere...
