Tiller 7' tiller
   / 7' tiller #1
Tdcw4
have a 2007 m5040 will it handle a 7' king kutter II tiller?
   / 7' tiller #2
Yes, should be a decent match just pick a gear that gives you the optimum travel speed for your property. My best guess is between 1.25 to 1.5 mph with this setup.
   / 7' tiller #3
I have a 2011 JD M5055 and I pull a 7' Frontier tiller. I pull in low 2nd or low 3rd depending on the terrain. I've been tilling at 5" deep and it works great.
   / 7' tiller #4
It will lug the engine a lot. I've got the same engine as you have in my L5040. I just tilled about a hour yesterday with my new Kuhn EL 62 210 tiller. Its 83 inches endplate to endplate. It would lug the RPMs on my PTO from about 525 to 490 and I didn't have it set to till but about 5 inches deep. I was tilling previously tilled ground also. Engine didn't smoke but it was grunting. I would have liked to have got the 72 inch tiller but the dealer had this one on his lot and was ready to deal so that is the one I traded for. Its rated as 42 HP minimum and my Kubota is 44 HP at the PTO. It will work for me and for what I wanted to do but the 72 inch would be a much better fit for my tractor. I'm pretty amazed as this tractor handed the JD 660 tiller (63 inches end to end) and would only lose about 8 to 10 RPM on the PTO rpm tilling very deep. The rotor diameter is the same on both my tillers. I had thought with the Kuhn just being 20 inches wider and C tines and side gear drive that it would handle it better than it does. Soil here is pretty light loam with some fist sized rocks scattered around.
UNUSED FUTURE SKID STEER HYD BREAKER (A51244)
UNUSED FUTURE SKID...
2022 ISUZU NQR 18FT FLATBED (A51222)
2022 ISUZU NQR...
2020 KUBOTA RTV...
2019 KUBOTA SVL65-2 SKID STEER (A51242)
2019 KUBOTA...
2015 Chevrolet Tahoe SUV (A50324)
2015 Chevrolet...
(6) HD 12' Pipe Gates (A50515)
(6) HD 12' Pipe...
