Mowing 7' bushhog for mx5100
   / 7' bushhog for mx5100 #1
ford farm boy
Bronze Member
Indiana
Mx5100,9N,ford 2000
Dose any one use a 7' a three point bush hog with a mx5100 if so how dose it do ?
I'm going to mow a grass field about 12" to 18' high . If it works what gear do you use
   / 7' bushhog for mx5100 #2
I don't have a 7ft cutter but if i were to buy a new one it would be a 7'er. I use a 6' flail and have never bogged it even in grass over 4' tall.
good luck.
   / 7' bushhog for mx5100 #3
I do not know your tractor but 7' can give my 265 MF (60 HP) a fit shaving the ground in two years of growth of fescue. Chipping 12'-18' grass is nothing.
HP is not my big concern because being 2WD it takes a lot of weights up front. My cutter does state Heavy Duty on the side. Hauling it can be a pain if the trailer is not real long trying to get enough tongue weight.
With a FEL and or 4WD you should be fine I expect. I only keep one front tire in the unmowed area so I am only cutting about 6 foot. In really heavy stuff to keep up my ground speed (for the not so thick spots I may only cut 3-4' foot.
A heavy cutter is hard on the arms when lifted if the weight is shifting but I like wider about 98% of the time.
That is a nice size tractor you have.
   / 7' bushhog for mx5100 #4
I've got a 7 bushhog and have used it on a ford 4000 which is very similar to your 5100 (around 50hp PTO). There were times when it would of been nice to have a little more power, but I would cut some pretty thick stuff with it (2' grass). Just needed to slow down a bit and let it chew some stuff. Not sure I would try using it on 1"-2" saplings.
Of Course on my M7040, it works like a champ. Amazing how much of a difference 15-20 hp can make.
The bush hog that Iam looking to buy for my mx5100 is a Ford 908 3pt 7' 2 spindle. Dose anyone know any thing about these ?
   / 7' bushhog for mx5100 #6
I have a MX5100 and bought a LandPride RCR 1872 6ft cutter. I'm wondering if I bought a big or "tough"enough one. I only have 15-18 acres to cut but some of it is pretty rough and bumpy. I'm interested in hearing opinions on this as well.
   / 7' bushhog for mx5100 #7
Land Pride seems to be a cut above so I expect you will be very happy with it. The 7' heavy duty bush hog is a physcial load to lift and the 265 MF is a very heavy tractor and it likes a little cutting out the tracks.
10-16.5 Tires on rims (A47384)
10-16.5 Tires on...
Magnum 4000 Series Hot Water Pressure Washer (A47384)
Magnum 4000 Series...
2017 Nissan Frontier Ext. Cab Pickup Truck (A51692)
2017 Nissan...
2018 HINO 268  NON CDL 26FT BOX TRUCK (A52141)
2018 HINO 268 NON...
Car Wash (A47384)
Car Wash (A47384)
TRUCKING INFO (A50775)
