$7.97 CREE LED bulbs at Home Depot
/ $7.97 CREE LED bulbs at Home Depot #1
ultrarunner
Epic Contributor
SF Bay Area-Ca Olympia WA Salzburg Austria
Cat D3, Deere 110 TLB, Kubota BX23 and L3800 and RTV900 with restored 1948 Deere M, 1949 Farmall Cub, 1953 Ford Jubliee and 1957 Ford 740 Row Crop, Craftsman Mower, Deere 350C Dozer 50 assorted vehicles from 1905 to 2006
I've tried a few variants and so far CREE has my vote...
Have to admit... no Sylvania yet.
/ $7.97 CREE LED bulbs at Home Depot #4
Yep, same price here.. In my Cree RFI thread, so far have not found a "dirty" Cree bulb including this new "flowthru" design. All have worked out of the box, and are still working. So far so good.
/ $7.97 CREE LED bulbs at Home Depot #5
Well, I've finished changing out all our light bulbs except the "appliance" bulbs (oven, microwave, refrigerators) and the two bulbs in the garage door opener. I tried LEDs in the garage door opener and they simply did not light. The most expensive ones were the four 3-way CREE bulbs at $21.97 each plus tax. And I had a hard time finding any chandelier base bulbs that were not too long to use in a 6 bulb fixture over the mirror in the master bath; finally bought Sylvania from Lowe's. So with 50 LED bulbs, I have some from Home Depot, some from Lowe's, some from Walmart, and some from Amazon.com.
/ $7.97 CREE LED bulbs at Home Depot #6
Report back in a month or so and tell us how much the electric bill went down:)
Am very interested how all the different bulbs hold up...
I put CREE 60W in Mom's 3-way lamps... she always used the middle setting and is happy with them...
Still have a case of compact fluorescents kicking around and lots of regular incandescents... bought in bulk for the rentals because almost without fail... majority of light bulbs are missing from fixtures when tenants leave...
/ $7.97 CREE LED bulbs at Home Depot #8
Hm... hadn't thought that.. If tenants will steal a $0.50 incandescent bulb, I wonder if they would think twice of stealing all of the $8 to $20 LED bulbs in a rental...I wonder:mischievous:
/ $7.97 CREE LED bulbs at Home Depot #9
Thanks for the heads up. I like the idea of not having the spiral of glass. I should be boarding my home up with the number of broken ones that have happened around here.
In case lot the 60W incandescent cost about 22 cents each.
The equivalent 20 year LED bulbs started at $12 each and now down to $8.
So one LED cost the same to buy as 55 incandescents... just something to ponder...
There may come a time where tenants will supply their own bulbs and take them with them when they move... already seen it at a house that was recently sold... the buyers were ticked off when every bulb in the large home was replaced by the give away compact fluorescents just before escrow closed.
Every year I have several light bulb service calls... 99% of the time it is tenant error... they have a box of bulbs and none work or they can't find replacement bulbs for the ones the utility installed under a low income energy program... read that to be the special energy save bulbs are expensive...
I will routinely convert back to standard fixtures at turnover just to minimize problems later... T5, T12, T8, circle line, plug in, etc... each a landlord nightmare.
/ $7.97 CREE LED bulbs at Home Depot #11
How much light comes out of the Cree 60W? Is it the same as a 60W incandescent?
/ $7.97 CREE LED bulbs at Home Depot #12
Google search says that the LED 60 watt equivalent uses about 10 watts to make 800 lumens. More Google searches say a standard incandescent 60 watt lamp produces about 860 lumens.
/ $7.97 CREE LED bulbs at Home Depot #13
The "warm white" ones seem to make about the same amount of light as a standard 60 watt, but the "daylight" ones seem much brighter to me. It is a much whiter light, not as yellow. The 82 year old mother in law that lives with us really liked the "daylight" version of the Cree bulb. I think as your eyes get older and "dimmer" with cataracts etc. it seems they respond to that brilliant white light better.
/ $7.97 CREE LED bulbs at Home Depot #14
I guess you're right about "older".:laughing: I like the "daylight" versions, although my wife hasn't decided for sure yet. She's accustomed to "soft white".:laughing: Home Depot (at least the one in Denton) has a set up with all 3 burning so you can kind of see the difference before you buy.
/ $7.97 CREE LED bulbs at Home Depot #15
Yeah I put one of the Cree 60 watts in the "daylight" version in my reading lap by my chair, replacing a 3 way with up to 150 watt setting, and I think the 60 watt "daylight" is as bright or brighter than the 150 watt setting on "soft white" incandescent bulb. Not to mention saving about 141 watts of electricity.:shocked:
/ $7.97 CREE LED bulbs at Home Depot #16
In the ad it says it is a 2700K bulb. Daylight bulbs are usually a 5000K bulb. 4100K is a very nice white and is very good for a reading lamp. I beleive they are getting rid of these 2700K bulbs for the new improved 4100K or 5000K bulbs.
/ $7.97 CREE LED bulbs at Home Depot #17
They have both models, "soft white" and "daylight" The soft white are about a dollar cheaper than the "daylight" . The LED's are more yellow.
/ $7.97 CREE LED bulbs at Home Depot #18
My concern with these lights is that they aren't bright enough.
For Moms overhead table reading lamp I had a 150W GE reading lamp which she liked a lot... I swapped it with a CREE indoor Floodlight and she says it is just as good... huge saving in electricity right there.
/ $7.97 CREE LED bulbs at Home Depot #20
And these, apparently put out less heat than incandescent?
Is soft white or daylight brighter?
2013 Nissan Juke SUV (A59231)
2013 Nissan Juke...
2017 Ford F-150 Crew Cab Pickup Truck (A59230)
2017 Ford F-150...
2018 Forest River Flagstaff Pop Up Trailer (A59231)
2018 Forest River...
Case skid steer wheels and tires (A61306)
Case skid steer...
2019 LGMG SS1932E ELECTRIC SCISSOR LIFT (A60429)
2019 LGMG SS1932E...
2021 HYUNDAI HX220L EXCAVATOR (A60429)
2021 HYUNDAI...
