6X8 Carryall
   / 6X8 Carryall #1
Glenn9643
Veteran Member
New Hebron, MS
MF 1455v 4wd, 1040FEL
Brad,
Responding to your question in another thread.
The carryall is 3ph. It doesn't have a dump, but I can raise it and drop the back end with my hydraulic top link, which makes it easier to rake out, etc. A friend and I designed and built this one, and I've never seen another as large. I needed it more when I had my previous tractor with no FEL. The floor is 3/4" treated plywood screwed to the steel framework. It has stake-pockets to allow easy on-off 24" sides and back. Because of it's length weight of the load is limited. I think I recall hauling eighteen 80lb sacks of quikcrete before the front of the tractor got too light. Since I have the FEL it might would haul more weight now but I don't need it to move heavy things. It's great for leaves, mulch, etc.
2022 Third Coast Reversible Plate Compactor (A51573)
2022 Third Coast...
2024 CYNERGY CARGO LLC 7' X 14' CARGO TRAILER (A51243)
2024 CYNERGY CARGO...
2019 Bobcat E32i Mini Excavator (A50322)
2019 Bobcat E32i...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A52128)
Ditch Witch 6510A...
